What are the most important parameters to monitor with the accessport while driving?
Joe_Stang
Glen Burnie, Maryland
Joe
2015 Mustang Ecoboost Premium
Hello all,
What are the most important parameters to monitor while driving with our tuning device and what should the numbers look like? I am using the Cobb accessport. Thanks for any helpful answers.
Busser48
La
2015 mustang ecoboost
Hello all,
Off the top of my head the oar, the inlet air temp, maybe charge air temp, knock sensors, or knock for each cylendar. I'm new to the Cobb myself, so I'm sure there are way more or ones I don't know much about. Just know octane adjustment is important and of course inlet air temps
TheWildman
Jazz Master
Columbia
Michael
2018 Kona EcoBoost Base (PP)
I have 6 of them active.
- Air Fuel Ratio
- Octane Adjust Ratio
- Comp. Outlet Temp. (turbo outlet temperature)
- Charge Air Temp (post intercooler temps_
- Catalyst Temp (Just to see how hot the exhaust is)
- Boost Pressure (gotta see all that boost!)
ThirtyThreePointThree
Austin, TX
'15 White EcoBoost AT
I use 4 of my 6 for the ignition timing correction on all cylinders. It can be a good indicator of somethings not right. Like I figured out my oil level was slightly overfilled once because of that.
My 5th is for charge air temps. Good way to know when the car is getting heat soaked.
My 6th is oil temp but that ones not really important since there's a built in gauge for that. I think the other five are.
juan_tony1
North Carolina
Juan
ECO DIB TANG
I use boost oar 2 for ignition coercion and the other 2 for knock counts total 6
Joe_Stang
Joe_Stang
Joe
Okay so what should these numbers be around for these parameters?
stevnoof
new jersey
2016 mustang gt base manual 3.31
Ingnition correction should be positive. Oar should be -1.0. Temperature should be whatever. Knock should be zero. Boost should be 30psi atleast...
Busser48
La
arghx7
cold
50 years Ecoboost
- Air Fuel Ratio
Comp outlet temp and catalyst temp are modeled. If you're modded they're not going to be very accurate.
Kjewer1
MA
Kevin
2015 Mustang, 92 Eagle Talon
Many of these alleged sensors are inferred. If you can't find a physical sensor, it's probably inferred. :)
There's no best or most important parameters to monitor. You're looking at 6 out of 100 things, and those 6 things will depend on what you're trying to do. At the track, I might have 6 things I want to see immediately before I even pull up the log. On the street, I'm looking at things that relate to whatever part of the tune I'm playing with. Always changing. I wish I could save templates in fact so I wouldn't have to look them all up manually every time, it's a bit cumbersome.
Fridge
San Antonio
Aaron
2015 Mustang EB Manual w/PP
I'm glad somebody finally asked this question. I've been searching and could only find Subaru guys talk about knock sensors and the octane adjust ratio. Wish somebody could explain how to interpret the different knock sensors. I've read conflicting opinions on the subject whether or not one instance of knock is to be expected or blah blah. If somebody could chime in that'd be cool.
Busser48
La
You can't get an accurate reading on the heads up display, just highs and lows. Data logging and reading the information is where u can truly tell your issues, that's where guys like Adam come in. That's about as much as I know
TheWildman
Jazz Master
Columbia
Michael
I'm alright with ballpark figures for now. I'll be changing those two gauges soon.
