Anyone running anything higher than 3.73's?
SVT-DADDY
World's heaviest S550
CT
2015 GT Convertible
My car is a lightly bolted on manual vert. Went to my local performance shop to get a price on doing a gear swap. I was asking about 3.55 or 3.73's. He said to go with 4.09's. :eyebulge:
There is also a chance that I could be bolting on a Whipple over winter, he still didn't flinch.
I ran the numbers. Highway cruising doesn't look bad, but first gear starts to look more like a tractor pulling gear than anything.
Anyone running them, any feedback?
cdq85
Greensburg, PA
2015 GT Boostey Pants
if you are considering a whipple, don't bother lol i have 3.73's with FI and i'm highly considering a swap to 3.55's. i couldn't image 4.09's with a blower. 1-4 gears would be insanely fast.
2015 Silver GT
East Haven Connecticut
2015 Ingot Silver GT Premium
4.09's? Way too much gear. I'm afraid to ask what shop recommended them. Jannety LOL?
SVT-DADDY
SVT-DADDY
CT
2015 GT Convertible
EFI
Masshole central
5.Br0
You guessed it! He actually said at minimum.
I think you should remind him that you drive a modern DOHC V8 with some balls, not a 4.6 single cam that could not get out of its own way.
Steep gears were the bandaid for a gutless engine decades ago. Nowadays you don't need to shift into 5th gear at 100mph just so you can accelerate quickly.
Most people would say 3.73s are a bit too much, so he wants you to go into the 4s?
kluke15
Reno, NV
Kenny
2017 Mustang GTPP
i have 3.73 NA and im not sure how i would like it with FI. i imagine i could manage fine with mine but to go into 4s with FI sounds ridiculous. i already find 1st borderline useless at times.
69mach1-395
central nm, usa
2016 RR GT/CS
Sounds like someone needs business badly, stay away from this shop.
BmacIL
Enginerd
Naperville, IL
2015 Guard GT Base, M/T
This engine with the MT-82 does not need 4.09s. 3.73 is already really short, basically the same final drive as a TR3650 with 4.10 in the 01-10 Mustangs. The coyote has a much wider powerband than the old wheezy 4.6, too.
Don't change anything if you're considering FI.
fcarpio
South Florida
2016 Mustang GT PP
I also have 3.73 but I am supercharged. 1st gear is useless, 2nd is better with sticky tires but it still lets go after 4.5k rpms. No fun until you hit 3rd gear which is powerful and grips. This is with the Nitto NT555G2 in the rear. I am going to try one more set of sticky tires (maybe the Michelin PSS) before I make the decision to go with 3.55.
2015 Silver GT
Ted knows a lot about the newer Camaros but is clueless on the newer Mustangs say 2011 to present time. Plus he overcharges for his work and parts. And God forbid you let him tune your car...........
Kahboom
Kahboom
Cathedral City, CA
2015 Mustang GTPP, Recaros/2014 Explorer Sport 4X4
I would consider 3.35 gears with torsen rear diff, or 3.15 with standard diff if going FI. Shorter gearing with the MT-82 higher then 3.73 is not ideal unless staying N/A or doing a Tremic swap. 3.73 gears is what I have now N/A and I traffic I mostly skip first and use second to start when crusing around town.
Vato
Chandler, Arizona
Frank
2017 Mustang Saleen White Label
I remember when my fox body mustangs had 2.81 or 2.83. Going to a 3.08 which were automatic rear end gearing was an upgrade. Obviously everyone went 3.55 due to the low 225hp. I always thought 3.31 was a good in between gear. That's what I have on my car now and with 450hp, more than enough gear. At 80mph I'm hovering around 2k rpm. IMO, I wouldn't go any higher and more so if you're throwing a blower on there.
Roadway 5.0
Strassejager
New York - USA
2016GT PP 6MT
[MENTION=23614]SVT-DADDY[/MENTION]
What's your outlet? If you drag race on slicks every weekend get the 4.09s; hell go to the good old 4.56s if you have an automatic.
If you're the daily driving type, 3.55 is the max I would personally have on a supercharged 5.0 S550. In your specific case, I would leave your stock gears alone and put the money into the blower fund.
whatsup62
Jupiter
I am running the 4.09's.... and they are the perfect gear with FI !!!
v
v
v
v
v
v
v
v
... if you are running a TR6060 :)
TheHydro
Las Vegas
2015 GT Performance Pack
I had 3.73s and once I put my whipple on it was too much so I went to the 3.31 and the power is much more useable now.
