Epiphany
I was lucky enough to meet up with and spend some time with Bruce Smith from Ford Racing a few months ago at PRI in Indy. He's a vehicle dynamics guru and top notch engineer and most recently is the man behind the FP350S (among other notable projects/parts). While he wasn't in a position to comment on other upcoming parts he was happy to talk about springs that were nearing release from FRP. In case you are wondering, the M-5300-W GT350 springs are not made by Eibach.
When I got home I called the Ford Racing dealer I have dealt with for nearly 30 years now, Mike and Belinda at Buyfordracing. He's located not far from FR and has been in the game so long that when I'm trying to find out more information or obscure/discontinued parts, he always makes it happen. So while the springs weren't available at the time, Mike took my order such that I'd get them the moment they became available. That moment was a couple of hours ago.
I also picked up a set of the GT350 R springs from Autonation (formerly Tousley) not long ago. Because spring prices don't break the bank I wanted to be able to compare the FRP to the R springs before making a choice. Here's what I saw.
First, the fronts. R in black and FRP in blue (same for all springs). Note that the GT350 chassis uses the same spring up front for either side (in either standard or R rates). Number of coils looks to be the same.
Rears. Note that the springs are counterwound, meaning that the springs are side-specific. Free heights on all springs are near identical but you can clearly see more coils on the FRP springs.
Note that the FRP rear springs indicate left or right by placing the appropriate letter after the part number on each spring.
Also, the FRP rear springs don't come with the OEM split sleeve that you see on the R or non-R GT350 springs. You could transfer the sleeve over if you feel you need them.
Coil thickness up front, FRP.
Front GT350 R.
Rear, FRP.
Rear, GT350 R.
Interesting to note that the FRP rears utilize an additional coil but that the diameter is smaller than the R rear springs and that the fronts are near identical across the board. The specs from FRP indicate a 20mm drop (or about 3/4") on all fours when compared to non-R GT350's. Personally, I'm looking forward to everyone in the group buy getting their springs too and seeing them installed. Mine won't go in until I have some caster/camber plates in hand.
Anyway, thanks FRP for making a GT350 spring available.
Front GT350 R.
Rear, FRP.
Rear, GT350 R.
