paxton tq booster- Anyone running it?
blkstang50
Dallas TX
2015 Mustang GT
Is this $750 part really worth it? What kind of gains would I see with the 3.6 pulley, 93 octane id1000/bap?
dubster99
Nor*Cal
2015 Ingot Silver GT PP
The tq booster runs the 3.33 pulley, and then use the wastegate to limit boost to 10-11lbs. You will see more peak boost on the 3.6, but more boost in the midrange on the 3.33 with tq booster.
isedawishy
GTPPTT6REIGHTY
Fort Worth
2015 GT
I run it and it's a noticeable power increase from the butt dyno, I'm on E85 though.I haven't made it to the dyno yet.
I'm not sure if the BAP would give you enough fuel though?
blkstang50
blkstang50
Dallas TX
2015 Mustang GT
So if you could pick one what would you go with? Sai li fuel system or Tq booster?
dubster99
Nor*Cal
It's fine for 93, not e85.
Depends on your ultimate goals. If it was me, I'd go Sai Li to run e85.
BrazukaV8
Los Angeles CA
Carlo
Mustang gt PP
I have a brand new tial mvs 38mm wastegate if you want. Just have it welded it'll cost you less
zaquhree
Orlando
2015 S550 GT
not worth it in my opinion and I built my own and did a lot of testing...11-14 good investment but not on these cars
run the 3.47" and no gate
Inigo
P2P Engineering
Denver
Alex
2015 PP GT 6spd
I'm running it on 91 at high altitude. Less peak boost but more tq
beefcake
Bethel
2018 Ford Mustang
our wastegate setup allows you to bring in the boost sooner and bleed off top. it your looking for extra.
our e85 fore system is a great mod too, and has alot of growing room vs other e85 systems that are going to cap you out.
e85 will give some good gains. let me know if we can help with one of our fore systems
beefcake
Bethel
2018 Ford Mustang
Very happy with my setup. Just wanting some details on exactly how effective it is...
Did you see the dyno graphs I have up
Hit me up with any questions
blkstang50
blkstang50
Dallas TX
2015 Mustang GT
Actually do have a question I'm ready to order this special and its called "MMR OIL PUMP GEAR / TSS CRANK SPROCKET COMBO (11-17 MUSTANG)" now when I select mmr gears it adds $100... Title says mmr gears and sprocket for $429 but when I select mmr prices jumps.. Is this a glitch?
Inigo
P2P Engineering
Denver
Alex
2015 PP GT 6spd
Any objections to running an 11 pound spring instead of 10? I feel the power taper off up top. (I made 11-11.7) pounds on the 3.6 pulley up top.
dubster99
Nor*Cal
Talk with your tuner.
beefcake
Bethel
2018 Ford Mustang
standard gear is the boudary with mmr sprocket
with other options selectable
