DRKHORS
Finally got my fluids swapped out today using the combo kit. The directions from OP make this swap pretty much fool proof. Having two pumps, teflon tape, and the tie to check the diff fluid level make this easy.
I was rather surprised at the color of the original diff fluid and the metal on the plugs. Car has just over 16,000 miles and has never been to the track. If you are on the fence about swapping the diff fluid I would certainly recommend it.
I've only put about 7 - 8 miles on the car after swapping, but I can already tell a difference in how much smoother gear changes are. It also seems to have quietened the transmission at low speed/low rpm ranges. I'm hoping that things continue to smooth out as I get some more miles on it! BG fluids and the MGW shifter make this like a new/different transmission! :cheers:
