Norm Peterson
corner barstool sitter
Maybe if you're never ever going to be shifting when you've got much of any steering input going on, paddles might make more sense. Like in Formula 1 with extremely fast steering ratios or the straight-line stuff where you don't plan to be steering away from straight ahead at all.
However, that still leaves the chance you'll tap some paddle a second time if/when the commanded shift doesn't happen as fast as you think it should, or it does and you don't notice it. That's not something as likely to happen with a lever that needs forearm and hand movement as it is with paddles that only need the much faster fingertip twitching. I've driven (albeit briefly) a few cars with paddles, one of which also had sequential at the lever. The lever was not just more natural, it was more accurate with less attention required.
Norm
Norm
