signs of a bad throttle body?
ManBearPig
Nashville
2016 GT
That would be the purge valve.
Will the purge valve operate in a way that makes the throttle body open/close slightly in a rhythmic pattern every few seconds? I have taken a datalog of this and can see the throttle body opening about 1* every 2 seconds for about 15 seconds. During this time the vacuum gauge will bounce slightly and the spark Will bounce several degrees (presumably to keep idle speed steady). The exhaust note audibly changes, and now I have discovered that with the hood open I can hear something clicking when this occurs. Does that still sound like the purge valve operation?
ManBearPig
Nashville
2016 GT
Additionally, could I just unplug the purge valve and see if it quits doing this? I'm sure I'd get a cel but can just clear the code later. If I disconnected the electrical connector would that trigger anything else?
jedcoRED
Makesnosenseiknowcrazy
Atlanta, GA
Jimmy
2016 GT Premium PP OW Ebony
My car was bucking and then dying when sitting in drive thru's. Took it to the dealer and it was the throttle body. Warranty'd and no issues now. The car felt heavy and slow for about 2 weeks and would just die when idling. They didn't say anything about the "purge valve" tho
It was like a new car when I got it back...so much faster.
ManBearPig
Nashville
2016 GT
My car isn't doing any of that
But I did find another thread with a video of exactly what my car is doing. Guy said he replaced the TB and it fixed the issue.
I have a 2013 F150 5.0. Anyone know if the throttle bodies are interchangeable? If so I can swap them out and see if it makes a difference.
markmurfie
Hawaii
Mark
2015 Ford Mustang GT
I think the F150 has a little smaller throttle plate. It may bolt on, but probably have drivability issues.
ManBearPig
Nashville
2016 GT
I disconnected the electrical connector to the purge valve solenoid and didn't notice a difference. This is not my video but my car is doing the same thing. This guy said a new throttle body fixed this for him
[ame]https://vimeo.com/200105745[/ame]
Nasteg
2016 Mustang GT PP Ingot Silver
Recently my car has been doing that idle surge on cold start up only and i just noticed the clicking noise in my intake yesterday, one thing thats been weird is that sometimes my idle wants to fall under 500 it feels as if its going to shutoff
al3x
Miami, Fl.
Alex
2016 Mustang GT Premium
My car has been making this noise since I installed the supercharger, never noticed anything wrong so I didn't look into it any further after people on here suggested it wasn't anything bad.
markmurfie
Hawaii
Mark
That may be your bypass valve and not your throttle body. Look underneath to make sure the actuator arm is not moving.
markmurfie
Hawaii
Mark
Specific too positive displacement blowers. At idle they have a bypass so that proper vacuum is created.
jshammond
Jason
I'm having this exact issue right now. Throttle body popping/clicking and then the sound is actually echoing out of the exhaust tips a second or two later; but when driving if I put the car in neutral to coast the last little bit to the stop sign or light, the RPMs will dip down to 500, and has actually stalled a few times. Did you get your issue sorted out?
Brmoorejr
Newnan georgia
2016 Mustang Gt Premuim
Its the throttle body.
I had the same issue and replaced mine and it works properly now.
Here is what mine sounded like
https://share.icloud.com/photos/08Nvf2-QArQS8tGvYWvu7yzqQ#Home
Bigred911s
Big Red
I ordered a new throttle body. I have the same ticking noise and can feel I when I put my finger against the TB. My idle at times dips below 500. I was getting random low rpm misfires on #s 4&8 on and off with flashing CEL. Then CEL would go off completely. I changed plugs and swamped coil to make sure they weren't the problem. After a week problem came back. I replaced the intake manifold but the throttle body is on back order. I will replace it as soon as I get it. I'm sure it's the dreaded TB. My GT is DD with 51k why miles on it.
