Removing hood liner to remove turn signal vents in hood
Bill88stang
2016 deep impact blue premium gt 6 speed manual
I was wondering when I remove the hood insulation liner there is a mustang emblem underneath, would be any effects to removing that permanently or not. Also to remove the vents to paint them are they bolted in or clipped in ? Just wondering before I risk breaking anything in removal.
Rebellion
Houston
2016 Competition Orange GT
They are clipped in. You can go without the hood liner, but someone had mentioned that it helps keeping the engine bay slightly cooler :shrug:
Southview
Viera, FL
Herby
2015 GT Premium Convertible
2 bolts and the rest of it is clipped. Where in Florida are you. Pm me if you are close. I can help:cheers:
Bill88stang
Thanks guys , I'm not far from st Augustine . Yea I thought it would be cool to not have the mustang hidden by the liner . Just didn't want it to possibly hurt the paint from the heat.
Chef jpd
Brooklyn, NY
Bill88stang
Well that was a fail for today, they came out nice until I peeled the tape around the turn signals and it pulled it all off. So I got mad and just peel them the rest of the way and put them back on the car.
NavyChief122
2015 GT
I removed mine and its fine. I hear my blower better now and IATs and CHT are cooler.
EcoSwag1990
West Chester, PA
2016 Triple Yellow GT
lmao. you need to take the tape off while the plastidip is still wet. I did the same thing but it wasn't that bad so I just left it. You can only see yellow from the driver's seat
Bill88stang
I was trying to but I guess trying to do one after the other I waited too long to remove lol
wireeater
Virginia
wheelwell.com
Rich
Shadow Black 2019 Mustang GT Premium+ PP 6spd
I actually just did this this weekend. I have the 2016 so I have the LED turns so mine has more wires that the none. I am curious if I can route them inside of the hood. There appears to be passages.
pmr2000
NC
2016 Mustang GT Fastback, 1975 Corvette Coupe
I took mine off an sprayed matte black...was considering plasti-dip...
EFI
Masshole central
5.Br0
Not that I'm doubting you, but what would be the reason for IATs and CHTs to be lower by simply removing the hood liner?
Chameleon
Gold Sponsor
S550 INTERIOR DRESS UP
www.ebay.com
Old wives tale......
It is?
"10-20-2003
CragarShinoda
There are around 9 plastic push pins that hold it on. Past that, remove the nut taht bolts the ground lead onto the body and it will come right off. Before you do though, let me tell you why Ford puts the hood insulator on the cars. It is not to remove heat at all. Though it may reduce the chances (Very slightly) of hood discoloration, it was not intended for that reason either. Let me bring you back to 4 years ago. I was racing at Bristol in a friends Cobra when... BAM!!! N2O backfire at about half track. The engine bay ignited and the hood was flaming. By the time that the car was pulled off the track the fire was out. I thought that the motor was shot, but believe it or not it was as good as new (once we replaced all of the components that the throttle bottle blew up). The only thing that was destroyed by the fire was the hood insulator. When the fire ignited the plastic push pins melted and the insulator fell onto the engine smothering the fire. I thought that this was just the good Lord looking over me, but after doing research and asking some very high ups at SVT, Ford, and Team Mustang I found out that the insulator was designed for just that reason. Saved my friend's motor and possibly my life. Just keep that in mind."
