CJ Pony Parts
- Dec 21, 2015
- Harrisburg, PA
- Website
- www.cjponyparts.com
- A large variety of Mustangs across all generations
Steeda Rear Camber Mount Adjustment Kit for all 2015, 2016 and 2017 Mustangs.
Looking for an easier way to fine-tune your 2015-2017 Mustangs factory camber? Well, take a look at this Steeda Rear Camber Mount Adjustment Kit from CJ Pony Parts!
Steeda has designed this Rear Camber Mount Adjustment Kit to work with your stock or aftermarket camber arm mounts. They utilize the factories full 2.0 degrees of adjustment to fine tune your Mustangs camber. Installation of the kit is a breeze with a 100% bolt-on design that can be installed with no permanent modification and without removing the rear Subframe. This kit uses high-quality class 10.9 bolts with locking hardware and class-exclusive plated steel brackets and bolts to provide a superior adjusting system.
In this video, Bill & the crew at CJ's will show you how to install this Steeda Rear Camber Mount Adjustment Kit on your 2015-2017 Mustangs from the comfort of your own shop or garage!
[ame="[MEDIA=youtube]HVTRRxkrdPI[/MEDIA]"]
Features:
- Works with stock and aftermarket camber arms
- Utilizes full 2.0 degrees of factory adjustment
- Class-exclusive plated steel brackets and bolts
- High-quality class 10.9 bolts with locking hardware
- 100% bolt-on with no permanent modifications required
- Can be installed without removal of the rear Subframe
- Includes Installation Instructions
- Made in the USA
Please Note: This Kit will NOT provide additional camber adjustment but will help utilize the full 2.0 degrees of adjustment from the factory allowing you to easily dial it in with a turn of the wrench.
As you look to upgrade the performance of your Focus ST or RS, there are lots of brands you could get your new parts from. However, few brands give you the exceptional quality that you can expect from a company like Steeda. CJ Pony Parts offers a variety of parts from Steeda, who is one of the leading manufacturers of performance parts for your Focus ST or RS.
Order this Steeda 555-4126 Rear Camber Mount Adjustment Kit for your 2015, 2016 or 2017 Mustang from CJ Pony Parts today!
Features:
- Made in the USA
