kcc0521
- Feb 24, 2015
- Falls Church VA
- Bo
- 2015 Black GT PP
I would like to get a new thread going about modifying as built data when changing a car from manual to auto. I will be posting updates as I progress in my swap. I intend to have a 100% stock appearing auto performance pack car with Utah my original vin. I am going to try editing the manual as built file in raw format then flashing it to the auto pcm. I have compared the two files and they are very similar. I also found the vin imbedded in the module codes using hexadecimal converter.
I need to determine if pcm data can be changed in fordscan. You also need to know if forscan will work with j2534 device.
I think line 5 in the data below is the line for auto vs manual in the PCM. The data on the left is my manual PP car and the data on the right is the auto car. I would like to load my as built data to the PCM then use the forscan to change the one line.
My CAR 1FA6P8CF9F5315160
PCM Modules PCM Modules
PCM 1 FFFF* FFFF* FF0C* PCM 1 FFFF* FFFF* FF0C*
PCM 2 FFFF* FFFF* FF0D* PCM 2 FFFF* FFFF* FF0D*
PCM 3 FFFF* 03FF* 1F32* PCM 3 FFFF* 03FF* 1F32*
PCM 4 FFFF* 2F14* 2176* PCM 4 FFFF* 2F14* 2176*
PCM 5 1F2F* FFFF* FF60* PCM 5 2F2F* FFFF* FF70*
PCM 6 FFFF* FFFF* FF11* PCM 6 FFFF* FFFF* FF11*
PCM 7 FFFF* FFFF* FF12* PCM 7 FFFF* FFFF* FF12*
PCM 8 FFFF* FFFF* FF13* PCM 8 FFFF* FFFF* FF13*
PCM 9 FFFF* FFFF* FF14* PCM 9 FFFF* FFFF* FF14*
