Muligan
ARRR!
- Dec 16, 2016
- North Central Illinois
- G0059 / Former Track Attack #14 "The Rented Mule"
I'm hoping that some of you engineering-types here can help me understand the math when it comes to the gearing difference between the 30-series Cup2s on the R and the 35-series Pilot SS.
I'm starting from the assumption that gearing in the differential and transmission are the same for R and the other versions of the GT350, so please correct me if I'm wrong on that. Even so, if there are differences in the trans and rear end, that just makes for more calculations, though, as there still may be a gearing advantage to the R, which is what I suspect is one of the main drivers of performance differential.
I'll stipulate to the fact that the R has the advantage in many other areas, including wheel and tire weight, overall vehicle weight, spring rates and weight transfer, stability control differences, etc. So, before we fall into the argument on all those points, let's talk about gearing and the effect that smaller tire diameters have on the R's ability to accelerate faster.
We'll need to know the ratio for each gear, as well as the differential, so hopefully someone has that info to supply.
According to Tirerack.com, the specs for these two tires in OEM form are:
Cup2:
Overall diameter -
305/30ZR19 = 26.3"
315/30ZR19 = 26.5"
Revolutions per mile -
305/30ZR19 = 792
315/30ZR19 = 785
Pilot SS:
Overall diameter -
295/35ZR19 = 27.1"
305/35ZR19 = 27.4"
295/35ZR19 = 767
305/35ZR19 = 758
As mentioned above, my guess is that if the gearing in the trans and differential are the same for the R and non-R cars, then the smaller tires are going to give a mechanical advantage in acceleration to the R, with a corresponding drop in overall top-speed potential.
Thoughts?
Cup2:
Overall diameter -
305/30ZR19 = 26.3"
315/30ZR19 = 26.5"
305/30ZR19 = 792
315/30ZR19 = 785
Pilot SS:
Overall diameter -
295/35ZR19 = 27.1"
305/35ZR19 = 27.4"
295/35ZR19 = 767
305/35ZR19 = 758
Thoughts?
